Just wanted to share some success for anyone interested in reducing exhaust drone.
My car has stock manifolds, primary cats, and the stock x muffler. LS9 cam and no DOD. The drone noise at 2,000rpm was unbearable.
https://m.youtube.com/watch?v=z5SY5oUTEcc
This guy has a good explanation to the science and calculations behind a 1/4 wave resonator and he also gives a link to a table you can use to find your required pipe length. It’s thorough but long winded. Basically you just need to measure average exhaust temperature and drone frequency. I used an IR temp gun and an app called Decibel X to measure the freq at 2,000rpm. Then you plug those numbers into his table and it gives you the length of pipe you need. You should use a bit smaller diameter pipe than the exhaust pipe you’ll be connecting to.
I measured 200F and 125hz so I want with 30.5” pipes. I added butt clamps to offer some adjustability. My tailpipes are 2.5” diameter so I used 2” for the j pipes. They fit really nice where the big rear mufflers used to be. For less than $100 I’m really happy with the results. I’d say my drone at 2,000rpm is 90% gone.
Homemade J pipes/ helmholtz resonator
- 63F1EC9F-8ECD-4588-B2F4-C35BFC1C3BD4.jpeg (5.09 MiB) Viewed 2064 times
- 0EE3CD1B-553C-4097-9C0E-705DAD74F47B.jpeg (3.31 MiB) Viewed 2064 times
- 7FD67DD8-735E-406E-B4EC-B90285AF6E5E.jpeg (4.66 MiB) Viewed 2064 times
- E514302A-6058-4FD8-A165-E9B81EA5B077.jpeg (3.67 MiB) Viewed 2064 times
Re: Homemade J pipes/ helmholtz resonator
I had looked at those when researching exhaust systems and I'm thinking of adding them to mine. I also get a drone at around the same RPM. It's not super annoying but it's still there. I may add them to my system but I have bigger problems to deal with at the moment (tranny issues).
