I don't have alot of experience with alignments... shop said I need front camber bolts. see attachment for alignment printout. also attached a photo of camber bolts from autozone down the street...I just want to make sure I get the correct bolts. thanks
Brandon
front end camber bolts
- 20230705_133408.jpg (2.99 MiB) Viewed 2165 times
- Screenshot_20230705_133741_Chrome.jpg (221.83 KiB) Viewed 2165 times
Re: front end camber bolts
so did they tell you that they cant get enough from the stock parts , or just say its not adjustable ? there is a stop bolt that can limit the adjustment if they dont see it
most of the time , there is enough adjustment with the stock parts , also the struts can have the holes ground out to gain a little extra adjustment
the smaller camber bolts are more of a bandaid , than a real fix
right, can't get enough from stock parts..I should add the car is lowered on ss springs, new struts
What year??
ive got a 14 with SS springs , and no issues with the alignment on 100% stock parts
you might have a different parts issue , or they dont know what they are doing
probably a combination of both...I put the bolts on and got it aligned just to be done with it for now.
