Yet another Brembo swap question...
I know there is a FAQ about the swap, but I couldn't find it. Anyways, I plan to use the Power Stop Z26 Street Warrior setup on my 2011, but they have the same pn as the Camaro. I read that the Camaro rotors are different due to the parking brake. Has anyone used these rotors and have had any trouble with them? I was also going to use Goodridge SS lines Thanks
Re: Yet another Brembo swap question...
you HAVE to use the 15-17 SS sedan rotors for the rear !!!
you would need customs brackets to use the camaro rotors , and custom made parking brake shoes , to use the camaro parts
And for the fronts, you use the Caprice rotors. The rear you also have to cut out the dust shields so they don't rub on the SS rotors.
