Yes I'm 99.9% sure Bank 2 was on the pass side until I started to look at a wiring Schematic and it shows Bank 2 on the LEFT side ??
Can someone please clear this up for me?
I'll attach a screenshot of the 2013 6.0L engine wiring schematic.
Is Bank 2 on the right or left side of Motor ???
- Screenshot_20231124_224539_Samsung Internet.jpg (357.33 KiB) Viewed 661 times
Walt (AKA:Capeasy) So. Cal.
Re: Is Bank 2 on the right or left side of Motor ???
You are correct. The 2011 FSM colors match what you have shown. They should have the left and right out of the connection location. Bank 1 has always been the side of the engine where number 1 cylinder is located.
I'm no electrical engineer and am probably the worse person to hand a wiring schematic to lol.
When I pulled up a 2014 wiring schematic it identifies the bank 2 on the righthand side , that's what confused me.
I'll try to post that 2014 image up.
Seems like there's no consistency between the two years 13 and a 14? Unless I'm reading it wrong?
But Steve (smwalker) was kind enough to send me schematic information so I can repair a Bank 2 Sensor 1 O2 sensor connector that I still am trying to pull the harness out to repair.
- Screenshot_20231209_111553_Samsung Notes.jpg (494.75 KiB) Viewed 651 times
on the LS , like all small and big blocks , #1 is front cylinder on the driver side , and this would be bank 1 pass side is bank 2
on a duramax bank 1 is pass side , and bank 2 is driver , the LFX maybe the same
