Cam swap/DOD help.
Capeasy
Cam swap/DOD help.
Post by Capeasy »
Just got most if not all my Parts from Texas Speed stage 2 DOD delete, along with a billet Circle D converter. My go to guy that was gonna help me flaked out. Is there any knowledgeable Caprice, G8, SS enthusiasts out there that can take on this task? Looking for someone not necessarily a shop in the So. Cal. Area. There's got to be someone out there who's done these and knows how to measure pushrod lengths and change out trunnion bearings. Lol
Thank you in advance to any good leads.
Walt (AKA:Capeasy) So. Cal.
mwc
Re: Cam swap/DOD help.
Post by mwc »
I just finished up a cam swap/DOD delete and converter install on my 14
For trunnion bearings I used a little $60 bench top press from Harbor Freight, and followed the Brian Tooley Racing video. It was my first time doing it, pretty simple and straightforward
As far as pushrod length, I used a Comp Cams length checker tool after watching a couple videos on how to use it.
I’m in northern Cali or I’d give you a hand
Black 2014 PPV 6.0 - BTR LS3 Stage 3 cam, Circle D converter, 3.45 swap, Solo 3” catback, Camaro 18s
Sonoma County, California
Turbopowered68
Post by Turbopowered68 »
I used the same one -- small Harbor Freight bench top press for my trunions.
2014 Caprice V8
1986 GN
1968 Chevelle
Capeasy
Post by Capeasy »
Thanks , yes it's much easier than the early small blocks to work on. My landlord just won't let me do major repairs here. If my Ex didn't get the house with the 3 car garage I'd be busy tearing apart that motor lol. I'm actually checking out an LS motor builder this week in Paramount that came recommended by a speed shop in Bellflower, says the guys really good and hopefully not crazy expensive. I'll keep you posted.
