Low oil pressure
Grandstaff
Low oil pressure
Post by Grandstaff » Sun Aug 20, 2023 10:24 pm
Just finished my dod delete using stage 3 tsp ls3 camshaft and kept my stock oil pump and the o-ring was fine. I started it up for a second a few times to build oil pressure and get everything oiled properly, but the low oil pressure light keeps coming up. Do I just need to keep letting it run for a second to build oil pressure? The oil pump was just fine and the inside was perfect no issues.
Re: Low oil pressure
Post by Mooseman » Thu Aug 24, 2023 2:07 pm
Did you block off the bypass in the oil pan? Did you replace the DOD valley cover with one that blocks off the lifter oil towers?
And a dumb question, is the pressure sensor plugged in? Try a new sensor? Is the engine noisy? I'd connect an analog gauge to see actual pressure.
Post by CrashTestDummy » Sat Aug 26, 2023 10:21 pm
And if you replace the sensor, there's a screen in the port for that sensor that sometimes gets gummed up. Carefully pull it, clean it and reinstall it before you install the new sensor.
