Turbo
landcrush
Turbo
Post by landcrush »
I’ve only seen one member on here with a turbo build. Anybody else done it on a caprice?
I’ve seen a few twin set ups on G8s, interested in any single turbo builds.
RM96
Re: Turbo
Post by RM96 »
Not sure if the owner of the car is a member of this forum, but HunterTuned on YouTube had a couple videos dialing in a single turbo Caprice. https://www.youtube.com/channel/UCanabQ ... ry=caprice
Oldblue68chevy
Re: Turbo
Post by Oldblue68chevy »
There is also a thread over on LS1 Tech in the forced induction forum of a PPV being built.
2011 PPV 9C3
Re: Turbo
Over in the Member Builds section, first or second thread:
http://www.newcaprice.com/forum/viewtop ... =36&t=3205
undrcvrppv
Re: Turbo
Post by undrcvrppv »
I'll be finishing mine up in the next couple weeks just working the bugs out now. I bought the kit from cartuning.ca it is ment for a g8 so there was a little bit of modification needed but not much and I documented everything and sent the kit builder pictures
landcrush
Re: Turbo
Post by landcrush »
undrcvrppv wrote: Sun Mar 29, 2020 9:56 am I'll be finishing mine up in the next couple weeks just working the bugs out now. I bought the kit from cartuning.ca it is ment for a g8 so there was a little bit of modification needed but not much and I documented everything and sent the kit builder pictures
That kit looks high quality. I’m just looking to get some design ideas layout etc. Does the crossover run under the trans or around the front ?
undrcvrppv
Re: Turbo
Under the trans definitely a higher priced kit but well worth it for the quality of parts and fab work
Turbopowered68
Re: Turbo
Post by Turbopowered68 »
undrcvrppv wrote: Tue Mar 31, 2020 12:15 pm Under the trans definitely a higher priced kit but well worth it for the quality of parts and fab work
have you done a write up thread on your build?
If so please post a link.
2014 Caprice V8
1986 GN
1968 Chevelle
undrcvrppv
Re: Turbo
Have not done a write up yet. Will try to post something tonight
rustybullet
Re: Turbo
Post by rustybullet »
what were you looking to do.
i have a 14' ss thats going twin turbo, i made my own kit using agp manifold adapters.
