T-40 cam bolts SUPER TIGHT!!!
3rd Coast BTH
Re: T-40 cam bolts SUPER TIGHT!!!
Post by 3rd Coast BTH »
Pursuit wrote: Fri Nov 05, 2021 11:12 am Those Torx bolts look like they are the TORX-Plus design. The flutes of the bit are wider and will withstand more force being applied to them. GM uses a TORX-Plus bolt on their transmission bellhousings. I went through the same hassle you did. I kept twisting/breaking my regular Torx bit sets.
You were absolutely correct Maurice. I ordered a set of Torx Plus bits from Lislie and they were a perfect fit. The new bolts have been installed at the correct 18 ft pounds of torque. There was no way those old bolts were torqued to 18 ft pounds! I've never heard of Torx plus before this. Thanks!
John
Post by Pursuit »
John,
They were probably installed with loctite. A small, directed flame, applied to the head of the bolt will really help also. Glad to help out.
Regards,
kevink
Post by kevink »
Pursuit wrote: Thu Nov 18, 2021 11:14 am John,
Regards,
Definitely loctited, which is why everyone said to use heat. You can't physically torque a bolt of that size in aluminum to the point that it destroys bits upon removal. It's the loctite that made them hard to remove.
