P0325 Code
counterattack
P0325 Code
Post by counterattack »
Hello,
I was driving my 13 Caprice on the freeway a little hard and the check engine light came on. I ran the code it it's a P0305 knock sensor bank 1. I was wondering what it could be and where I should look. Should I order a new bank sensor, if so which one should I get? Also some people say the wiring may be toast so how would I go about remedying that as well? Is there a new harness I can buy or do I need to splice the wire? Where would the wire likely be failed at?
Thank you
Re: P0325 Code
I guess the P0305 in the post is a typo?
Inspect the wiring. It that checks out, change the sensor. It's cheap enough to shotgun that. If that doesn't solve it, then we can look deeper.
counterattack
Re: P0325 Code
Yes it was a typo it's a P0325 code. On the FB page people were saying the wiring it is pretty normal for the wiring to be shot so I'm going to order a knock sensor wire with connector as well.
I was also considering a n alternator wire/connector you wouldn't happen to know which one that is would you? I have been having some weak starts
Re: P0325 Code
If you mean it sounds like it's cranking slow, that's just how it is. Just do normal checks for alternator and battery output and go from your results. Haven't heard of the alternator connector causing issues.
