How hard is it. Pan drop and filter change
Re: How hard is it. Pan drop and filter change
Post by s/c'd cav » Wed Nov 24, 2021 10:50 pm
Mooseman wrote:
Wed Nov 24, 2021 6:19 pm
What about with headers? Maybe the area is more open with those? I might give it a shot next spring when she's out of hibernation.
I also hate paying too much for anything that has a cheaper alternative that works the same or better.
exhaust doesnt matter to much , alot of the way the pipe is bent and the room between the firewall , motor , and trans , plus the location of where the tube goes into the trans
having the pass head off does make it easier from what ive heard , ive only fought with everything in its place , or having the motor and/or trans out which makes it a walk in the park
Car54
Post by Car54 » Sat Nov 27, 2021 6:49 pm
Ok, thank you all for the info, parts supplies, and vendors.
I thought I was going nuts as I couldnt find the damn trans tube!
Forgot that they stopped putting a $1.00 part in most of the cars.
