6L80 Goes into false neutral
Holdendeeznuts
Post by Holdendeeznuts »
Hello,
I recently purchased a 2011 caprice ppv from the bay area CA. When I drive the car like a grandma (staying under 2500 rpm) it shifts through all the gears, no slipping, drives completely fine. You would be able to tell there is anything wrong with the car. HOWEVER once you mash your right foot into the ground, the car will try to down shift and rev out as if you are in neutral. Kinda feels like you missed a gear, or hit a false neutral on a motorcycle. Eventually the car will go into limp mode after doing this a few times and then it will only hold 3rd gear.
SO I scan the car and find 2 codes. U0073 (control module communication bus "A" off) and P0700 (transmission control system malfunction) which I believe is a very generic code for the TCM.
Based off this I hope that it is a solenoid or the TCM itself? My fear is that the clutches are fried and the trans needs a rebuild. I have yet to pull off the oil pan, but plan to after the holidays, just a bit busy right now.
If anyone has dealt with this before any input is appreciated.
Reno/Tahoe, NV
2011 Caprice
2018 Toyota Tacoma Turd offroad
1978 yamaha xs750
2021 yamaha YZ250
cerbomark
Re: 6L80 Goes into false neutral
Post by cerbomark »
first thing is make sure fluid level is correct.
2016 C1
andrewquant
Post by andrewquant »
Are you able to data log the pressures for the PCS Sol 1-5? If so, give us a datagram. Also include trans slip rpm and torque converter slip rpm. Need to see if the slip is trans or TC. Check the fluid level first, but there is a good chance you may have a leak in the trans or pump. That can be verified with a mechanical gauge on the test port and a tech2 to command pressure. Try and see which gears it slips in. Each gear (except 1st and R) uses two clutches. So if you can figure out what gears it always does it in, or never does it in, we can isolate it to one clutch. The clutches are 1-2-3-4, 3-5-R, 2-6, and 4-5-6. If you bash it from a stoplight and 1st gear holds, they your line pressure and your 1-2-3-4 clutch are prob ok. You can cross that one off.
Water/Meth + 180hp N20
Holley 120lb injectors
common problem is the #1 check ball get small and get jammed in the plate holes.
See this vid for an example. quite interesting.
https://www.youtube.com/watch?v=HSvWikVP-4M
GammaFlat
Post by GammaFlat »
It is surprising that the check ball is not steel?! Also surprising that the ball shrunk so much. Is that plastic? Nylon?
Holdendeeznuts
A lot of knowledgeable feedback. Thanks. Going to try to work on this thing over the weekend….after I dig the car out of 3ft of snow :)
Reno/Tahoe, NV
2011 Caprice
1978 yamaha xs750
2021 yamaha YZ250
Holdendeeznuts
UPDATE: trans fluid was a bit low. Topped it off, car still has the issue. Going to drain the oil and look at the valve body. Might be the check ball.
Reno/Tahoe, NV
2011 Caprice
1978 yamaha xs750
2021 yamaha YZ250
Holdendeeznuts
UPDATE: dropped the pan. Not much debris in there. Assuming clutches are good.
Took valve body off. Split it. Looked at the check balls. They are all where they are supposed to be. Going to check solenoids on the TECHM next. Beginning to think the TCM is the issue. Not 100% sure at this time.
Reno/Tahoe, NV
2011 Caprice
1978 yamaha xs750
2021 yamaha YZ250
While you got it apart consider the deeper pan and larger mouth filter modification. It supposedly fixes the flare problem but I have never hear of the flare problem causing a limp mode situation. Why I initially thought he check ball might be your problem.
Deep Pan Mod:
https://www.newcaprice.com/forum/viewto ... =821#p7418
