Whiteline Lower Radius Arms
JRWolff
Post by JRWolff » Wed Jan 18, 2023 1:44 am
Hi All,
Has anyone tried the Whiteline Front Lower Radius Arms (WA386L and WA386R) on a 11-13 Caprice? They are listed for a G8, however, I think most of the front suspension is interchangeable between the G8 and Caprice. Looking for any feedback or results if you have tried these.
Thanks,
John
Twin 2012 9C1's
1991 GMC Syclone
1986 Buick Grand National
JRWolff
Re: Whiteline Lower Radius Arms
Post by JRWolff » Sun Jan 29, 2023 3:32 pm
As a follow up, I contacted Whiteline and they confirmed fitment on the 11-13 Caprices. I held the Whiteline right side one against the factory one installed on my Caprice and also could not see any visual differences. So, it appears that all is good.
Just curious why GM would have different part numbers for the 08-09 G8 compared to the 11-13 Caprices:
Left G8 - 92253411 Caprice 92253413
Right G8 - 92253412 Caprice 92243414
Any insight is greatly appreciated.
Thanks,
John
Twin 2012 9C1's
1991 GMC Syclone
PSM09
Post by PSM09 » Tue Mar 07, 2023 9:30 pm
FYI, I just found that the lower trailing arms (92253413, 92253414) for the Caprice are ALMOST identical to the G8 pieces. However when placed side-by-side the Caprice arms have a larger diameter tapered stud. Heavier duty, I suppose.
2009 Pontiac G8 GT
Pacific Slate Metallic
240,000 miles, still going with original owner
JRWolff
Post by JRWolff » Wed Mar 08, 2023 1:05 am
So, if i understand you correctly, the Whiteline parts for a G8 then will NOT fit a 2011-2013 Caprice?
Twin 2012 9C1's
1991 GMC Syclone
PSM09
Post by PSM09 » Wed Mar 08, 2023 11:28 am
That is correct.
2009 Pontiac G8 GT
