Complete G8 GT Suspension on 2011 PPV, direct fit?
73TA
Post by 73TA »
Did alot searching. Could not find the answer to this.
Real simple, is it a direct bolt in? Springs, shocks, struts, everything. Do not want to mod or cut anything.
Got a local guy parting out a 2009 GT.
Mike
Re: Complete G8 GT Suspension on 2011 PPV, direct fit?
why ? its a down grade
but yes the parts are a bolt in
enginelord
Post by enginelord »
I also am curious as to the reason for this change? But yes, fits.
that guy E
Post by that guy E »
I wouldn't necessarily call it an up grade or a down grade. It will lower it a little bit and soften up the ride
amx1pxp
Post by amx1pxp »
Reason for the mod is pretty simple. The stock PPV suspension is too firm for his (and my) taste. My two cents worth... (I've been considering the same change).
try installing the 12-13 struts shocks , its well known the 11's were valved stiffer
