steering vibration issues between 55 and 70 mph
Greenarrow
Post by Greenarrow »
Hey guys Can somebody shed some light on steering vibration issues between 55 and 70 mph ? I'm having this issue on my 2014. Any Help or insight would be highly appreciated.
Rear Tire info : 285 35 ZR 19
Front Tire info : 245 45 ZR 18
Ridgeppv
Re: steering vibration issues between 55 and 70 mph
Post by Ridgeppv »
Need to check front suspension. And try rotating the tires if you can. Start from there
JUNKYARD_JACK
Post by JUNKYARD_JACK »
http://www.newcaprice.com/forum/viewtop ... =18&t=4056
Check out that thread lots of good info there. I fought against a vibration for a while.
I replaced my radius arm bushings and that helped a ton. I am doing struts next and I think that'll have all my vibrations fixed.
Greenarrow
thanks a lot everyone for replies.
Really appreciate it. :D
no 5-0
Post by no 5-0 »
Did you ever track it down? I have a similar highway speed vibration, which is usually indicative of a balance issue. Jacked the car up and saw that my drivers side tie rod end is wiped, going to start there and replace the sway bar end links while I'm at it!
