Camaro Wheels not fitting
scott42076
Post by scott42076 » Fri Sep 18, 2020 7:11 pm
20” staggered Camaro SS wheels. I am trying to install on my 2014 PPV. The tears don’t set flat against the rotor and thus wobble. Front seems fine. What am I missing?
Re: Camaro Wheels not fitting
Post by Navy Lifer » Fri Sep 18, 2020 9:04 pm
the wheels absolutely should (will) fit - are you removing steel wheels? Zeta application wheels are all the same hub bore/register size and do interchange.
Check for rust buildup on the hub register (the part that extends beyond the rotor/wheel mounting surface). Use some elbow grease, rust-buster, wire brush, emery/crocus cloth to get rid of any junk /corrosion. Check wheel bore(s) to be sure they're not banged up in some way.
scott42076
Post by scott42076 » Fri Sep 18, 2020 11:50 pm
Thank you. I finally got them to seat properly
elc32955
System Manager
Post by elc32955 » Wed May 12, 2021 7:59 pm
Just resurrecting an old post to reinforce the point Bill made. I just swapped to the 18" LT wheels off a 2016 Camaro from my old dinged up & rusting police steelies. The tire shop I was using could NOT get the wheels to mount correctly on the first attempt, same problem - not seating properly on the hub. The manager had them take the surface down to bare metal by cleaning the rust off the hub register (106K worth of corrosion) with a wire brush, after this was done BAM! Wheels slid right on.
SO... if your 2016-2019 Camaro alloy wheels will not fit at first try, you know what you have to do. Clean up those hubs!
System Manager and your tourguide for the day. 2015 Caprice 3.6, former NC DPS car, for right now bone stock., .
