Newbie in Melbourne..... FL.
Posted: Mon May 03, 2021 6:55 am
by Monkeyeggs
OK, so this site is great! But I am not sure what to do next. My key is stuck in the ignition. Tried the fuse and relay route, my mirrors work. The shifter pin seems to be working properly, although it looks to have some grease on the micro switch. What other culprits could I look at? Switches, solenoids bad? Can i get the key released temp thru the column?
Re: Newbie in Melbourne..... FL.
Posted: Mon May 03, 2021 8:18 am
by elc32955
Welcome! I'm actually in Rockledge, lol. What year/model of car do you have? Was wondering if you ended up with one of those cars from Melbourne Beach or IHB that were sold a while back... also the year differences may help pin down your problem a bit.
I've not run into this problem before, locally the closest Zeta expertise I know of might be the G8 group over in Orlando or perhaps Chris Henry in Tampa at CHMotorsports. You might try shooting Chris an EMAIL, his website is
https://www.chenrymotorsports.com/ . He's a darned good diagnostician and tuner/builder. Folks here are very good as well...
Posted: Mon May 03, 2021 3:04 pm
by Monkeyeggs
I picked up a 2012 9c1 this weekend from a seller down in Deerfield. It was a Coconut Creek PD car. Runs great, but i sure would love to get the key out lol. I am having to disconnect the negative when i park it. I'm actually in Suntree.
Posted: Mon May 03, 2021 3:14 pm
by elc32955
Yeah, that would be frustrating. You can try Bob Steele, I think they do the service on the TPD cars that the city garage can't handle (Titusville has ten 2012's). If it'll drive up there that may be the quickest bet, just hold onto your wallet! They did work on my 2011 when it was still under factory warranty. The other thing you might try is to check with Viera Gattos, tell Rick Hickman I sent you in there. He's the store manager and a good problem-solver.
Good luck! When it gets fixed PM me & maybe we can get together. Love to see your car, I do also have some 2011-2013 parts stashed if needed. Just moved out my steelies from the 2015 I have...
Posted: Mon May 03, 2021 3:58 pm
by Groundczero
Nice to see another Brevard car, I am in Palm Bay, FL. Hope to see you around.
Posted: Mon May 03, 2021 7:36 pm
by GammaFlat
Hey Monkey,
I've had my column apart and do not recall how easy it was to get at the solenoid but I can tell you that things don't look too complicated in there. Whether you are removing the solenoid or energizing/de-energizing it, it may be accessible by splitting the upper and lower column cover. There are at least 4 clips. Mine are easy to take apart (too easy) but that's probably because they've been taken apart plenty.
Are you sure you were looking at the correct relay? That's the kind of thing I'd do
Regards and welcome!
Posted: Mon May 03, 2021 9:40 pm
by Monkeyeggs
Yeah I got the correct relay as far as I have investigated. Plus I have no other issues like none working mirrors. I even swapped relays just in case. I am giving it hours of attention this weekend. Hope I can pinpoint the problem. Hoping its just that little micro switch in the shifter?
Posted: Thu May 06, 2021 7:39 pm
by Monkeyeggs
Key out! It was the 10 amp #16 fuse as it should have been. I feel stupid, the fuse looked fine, but it must be broken and my old eyes can't see it. Replaced and key is turned out.
