Where is the best place to tap in for the wiring?
How important is the light it self selection - I don't want to take out the factory smoke from anything.
Anyone actually make a Vent out of the OE "Vents" to extract heat from the engine compartment?
Thinking about making own custom repeater and have?
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Re: Thinking about making own custom repeater and have?
I looked when I replaced mine with a painted pair, and there's an inner fender panel that pretty much covers all that up. You'd have to pull the fender and cut a/some hole(s) in the inner panel for that to work. Not sure what you'd gain though, really.
