Oil pressure gauge installed
Finally got around to installing my speedhud oil pressure obd2 gauge works good it’s nice to know what’s going on I left the Amazon special multi gauge that I bought originally for oil pressure and that was the only reading that didn’t function so I run it for coolant temp now
- 7F11937F-9D33-4CDF-A72E-F066A4B6CED2.jpeg (2.69 MiB) Viewed 728 times
Re: Oil pressure gauge installed
Hi Bill,
I have had one of those gauges sitting on my garage shelf for the last 6 months. Just cant seem to make the time to install it either. Any tricks or advice for when i do install it?
Thanks,
John
Thanks,
John
Twin 2012 9C1's
1991 GMC Syclone
1986 Buick Grand National
1991 GMC Syclone
I got a obd2 plug form Amazon to make install easier and not to have to splice into factory wiring and just got 12 volt key from the police upfitter wires under the console I didn’t hook in the gauge lighting yet but most likely going to put a fuse tap on the swc backlight fuse ran out of time and lack of tap I’ll update when I get to that point
bbfly-A9 OBD II OBD2 16 Pin Splitter Extension 1x Male and 2X Female Extension Cable Adapter (2FT/60CM) https://www.amazon.com/dp/B0711LGRGQ/re ... EqNluK4pkr
