Aux battery removal - weight
Re: Aux battery removal - weight
Lord Vader wrote: Fri Nov 12, 2021 10:55 am So... Does the car use both batteries to start and run?
answered 101 times now
NO , the 2nd batt is aux equipment only
Lord Vader
Post by Lord Vader »
Sanford wrote: Thu Jun 03, 2021 6:30 pm They are in parallel when the car is running. The positive cable circuit is opened up when the isolation relay on the aux battery bracket is de-energized. You should head a clunk in the trunk when you turn the key on.
This is why I asked.
I saw some patrol cars that have a switch that combines the batteries for emergency starts, I guess. I just trying to figure out how to do that.
Post by elc32955 »
RV's commonly do this with the coach & house batteries, the ones I've seen either use a marine-type battery tie switch or a starter-type solenoid tied to a switch on the dash for momentary action. You're going to need some current-carrying capacity no matter how you cut it, the question becomes where & how to route the bridging cable... and how you want to switch the bridge on & off.
elc32955 wrote: Sat Nov 13, 2021 5:25 pm RV's commonly do this with the coach & house batteries, the ones I've seen either use a marine-type battery tie switch or a starter-type solenoid tied to a switch on the dash for momentary action. You're going to need some current-carrying capacity no matter how you cut it, the question becomes where & how to route the bridging cable... and how you want to switch the bridge on & off.
what he said , plus a switch like drag racers use to cut their batteries off is good enough to use
its a simple enough job , run a short cable from the pos terminal to the switch , then another short cable to the terminal where the cable comes from the main battery to the aux battery , mount the switch and you are done
Post by elc32955 »
If you use a switch, my preference is a Cole Hersee. Those are generally the gold standard, I've used the imported stuff before and had one physically break on me. I don't have the grip of Hercules, the d*mn thing just broke. Metal fatigue from the occasional throwing of the switch. Sometimes the trade-off for cost vs. quality is just not worth the hassle.
Lord Vader
I agree with the Cole-herse recommendation. I have a constant-duty solenoid on a race car I have.
I'm gonna look at the PD cars and see what they used. I'm trying to get my AUX battery replaced under warranty. Once I have it back I'll mess with it.
