2011 PPV
Crutchfield was no help as was the same with metras site.
Does anyone know what metra speaker adapter fits our cars? Saw a youtube video and was hoping the info would be there but sadly the guy just used to screws to hold it to the orig adapter for the stock speakers.
Just don't want to buy 5 or 6 different ones to find the right one.
door speaker adapter?
Re: door speaker adapter?
Metra doesn't seem to make them. I also just screwed the aftermarket speakers to the factory spacers and it worked fine.
You will need to get ahold of these most likely if you want aftermarket.
Front:
https://aerpro.com/aps290f#
Rear:
https://aerpro.com/aps290r#
Front:
Rear:
2015 Caprice 6.0
The is the adapter I used for the front doors on my 2014. Used a combo of high density foam on the back and low density foam on the front to seal it.
https://www.scosche.com/installation/20 ... er-adapter
Exactly what I needed! Will be ordering these, thanks!BluesBro wrote: ↑Thu Oct 14, 2021 9:23 am The is the adapter I used for the front doors on my 2014. Used a combo of high density foam on the back and low density foam on the front to seal it.
His ‘11 has a different design to the speaker mounting plate though.
2015 Caprice 6.0
Good to know, I have not taken the door panels off the 2013 yet so I had not seen the differences.DapperDanMan wrote: ↑Fri Oct 15, 2021 8:26 amExactly what I needed! Will be ordering these, thanks!BluesBro wrote: ↑Thu Oct 14, 2021 9:23 am The is the adapter I used for the front doors on my 2014. Used a combo of high density foam on the back and low density foam on the front to seal it.
‘13 has a pretty generic 6.5 inch speaker with three screws holding it into the factory plastic mounting plate, so you can just reuse that mounting plate if you want.
2015 Caprice 6.0
