Trunk release works on both doors with the key on. It also works from the remote.
But… doesn’t work when key is out and car is off. Is there a way to fix this? My SSV Tahoe, Saturn shoot my sons ‘97 Lesabre works with key off.
BCM, fuse, connect this to that? What make it happen?
Trunk release
Re: Trunk release
I believe it's programmed that way because it's a police vehicle. All police vehicles that I know of were like that. Not aware of a different BCM programming option to change that.
Re: Trunk release
Being a police vehicle I can accept that, a bit ridiculous if I may say.
Re: Trunk release
I bet it could be changed without much effort. The BCM triggers the relay to open the trunk, but the power to that relay is hot at all times. If I wanted to do that on my car I'd simply change the wiring right at the BCM so the trunk switches directly controlled the relay, without involving the BCM.
Joe
Joe
Re: Trunk release
Found a work around the BCM on the 11-13 but 14+ was a bit different and we cannot get to the relay as it is soldered to the board:
viewtopic.php?f=21&t=3955#p29639
