2014 Caprice
A/C system is completely empty.
How much freon do i need to fill the system to the max?
Thanks for you help.
2014 Caprice -- AC system freon capacity ?
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Re: 2014 Caprice -- AC system freon capacity ?
I recall that you had a broken motor mount. Hopefully you've got your motor mount fixed because it is likely the cause of your problem. Broken motor mounts break the A/C line. Maybe someone here can help us with where the line breaks/what needs to be replaced/repaired.
In terms of how much, My 2013 says .48kg of R-134 on a sticker under the hood.
We emptied it when I did the cam swap and i've had a torque strap on.GammaFlat wrote: ↑Wed Mar 24, 2021 9:05 am I recall that you had a broken motor mount. Hopefully you've got your motor mount fixed because it is likely the cause of your problem. Broken motor mounts break the A/C line. Maybe someone here can help us with where the line breaks/what needs to be replaced/repaired.
and since you just reminded me (thanks ) about the motor mounts, I literally just ordered a set of them better ones.
https://holdenpartsusa.com/collections/ ... -mount-set
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
