Selling some spare parts - trying to generate cash for a car trailer.
6.0 LS L77 Long Block** from Caprice PPV -82K miles
Also includes Texas Speed DOD delete kit (was over $850 as configured) Kit contents LS9 Camshaft 12638427, Chevrolet Performance LS7 Lifters 12499225, GM Head Bolts 17800568, L92 Valley Cover 12598832, GM Crank Bolt 12557840, TSP/GM Head Gaskets, Four LS2 Lifter Trays, LS2 Chain Dampener, Timing Cover Gasket, Front Crankshaft Seal, Water Pump Gaskets, New Timing Chain
$ 3000
6L80 Caprice PPV Transmission - 82K miles, all stock - worked fine when removed - was my just in case backup - no converter
$ 700
Two 18" stock Caprice PPV Rims and Centers with Hoosier DOT Drag Radials 245/40-18 - less than ten passes. (Went 1.62s sixty foot) (Tires were $275 each)
$ 350
All items are pick up only, 30 miles SE of Pittsburgh, PA
L77 Long Block, Transmission, Drag Radials/Wheels
- HoosierPPV.jpg (959.03 KiB) Viewed 1676 times
- 6L80.jpg (931.65 KiB) Viewed 1676 times
- Cam.jpg (754.93 KiB) Viewed 1676 times
- DOD Kit.jpg (760.53 KiB) Viewed 1676 times
- L77.jpg (659.02 KiB) Viewed 1676 times
Re: L77 Long Block, Transmission, Drag Radials/Wheels
Did you sell the engine parts with the engine?
No, he just wanted long block. I still have DOD delete kit
OP you still got that Texas speed DoD kit?
