What is this behind the bumper /grille?
Im prepping for a tear down. And am trying to identify the lines and other things before I get started. Does anybody know what the black box under the cooler is? It has a corrugated hose or tube running under the headlight on the driver side
- 20201122_180522.jpg (8.19 MiB) Viewed 4079 times
- 20201122_180529.jpg (6.45 MiB) Viewed 4079 times
Re: What is this behind the bumper /grille?
I assume the top cooler is trans? I figured out there is no oil air /oil cooler already and these cars are equipped with water /oil cooler
It's the windshield washer reservoir.
Whaaat kevink.... I guess I'm trying to figure out if people replace them when the add LSA heat exchangers. What is the other cooler for sure? Trans?
The cooler that you see there is the trans cooler and yes, the box under it is the windshield washer reservoir. I removed both of them on my car (and installed a bigger trans cooler). I never use windshield washers on my nice cars that aren't driven in the elements, so I don't need the reservoir. LSA guys either delete it or put a smaller one somewhere else.
