<sarcasm> It's nice the government didn't over react. </sarcasm>Mooseman wrote: ↑Fri Oct 08, 2021 9:58 am It came with the lights and all? Man, that would be illegal here, especially after what happened here in Nova Scotia https://en.wikipedia.org/wiki/2020_Nova_Scotia_attacks. In fact, the RCMP has stopped selling their old PCs to the public even if they are stripped.
2013 PPV Weekend Warrior/Mad Max Build
Re: 2013 PPV Weekend Warrior/Mad Max Build
V6 (silver one) is now daily driver for my son.
It really runs well, the V6 is no slouch at 300 hp. Rides like a Caddy
Had mine to the track - went 11.77, but differential axle seal let go only letting me make one pass.
(LOTS of smoke - rear end grease directly on hot exhaust)
Noice! 1 A video from the track would be cool too! Here's an easy way to share it here, if you have a Google account (Gmail, YouTube, etc). https://support.google.com/drive/answer ... %3DDesktop
Hey Barry, what was the width on the rims you widened? I acquired a set of 20X11 with 315/35/20's for the rear and 20X9 275/40/20's for the front from a Zl-1 track racer. Was planning on using on a different project and they are just to big. I ran the tire calculator for yours and mine and came up with this:
315/35/20 28.7" H, 12.4" W
325/45/20 29.5 H, 12.8" W
You stated that your tires are 30.2"
I assume that my wheels and tires will fit if the offset is correct?
What do you think?
Mike
What do you think?
Mike
I have a pretty similar setup. 10” widened oem rims on 315/45. Did you do anything to dealBarryM wrote: ↑Sat Nov 13, 2021 8:00 am V6 (silver one) is now daily driver for my son.
With the ABS not working due to the tire diameter mismatch front to rear? The warnings are pretty annoying. I couldn’t find anything programmable in the ABS module to allow a different size front to rear.
2013 PPV Phantom black 1,077 RWHP 1,015 RWTQ 9.9@148
LS3 stroker 417ci, Callies crank w/ Malhe pistons & Darton sleeves. 11.5:1
Procharger F1a94. 22 psi boost E85
Water/Meth + 180hp N20
BTR custom cam 235/257 .638/.629 116, BTR shaft rockers Johnson 2126 lifters
BTR Trinity intake Kooks headers w/ Solo exhaust 3"
CDT Level 4 trans build w triple disc TC
Holley 120lb injectors
MT ET Street R 305/45/R18 on 10" widened OEM wheels.
No I have not - Shortly after pulling out the garage it throws a couple fits about ABS then disables.
Congrats on a great build in your signature - you will have a lot of fun with that ride !
