Into my DOD delete - finally. Just about have the heads off. I wanted to get some baseline oil pressure numbers before I tore it apart but there is no oil pressure indication that I can find anywhere in the various dash displays. How are you guys monitoring oil pressure. Aftermarket gauge?
Thanks,
Paul
oil pressure
Re: oil pressure
You can use an OBDII tool (like Elm 327 - about $14) and phone app (like car scanner - free I think) to see your oil pressure. You can also see lots of other "vitals".
For extra credit, you can show the gauge values on your Android supported radio. This is tricky since getting Android support on these cars is challenging.
Re: oil pressure
Thanks Gamma. I'll give it a try. I'm thinking maybe I could find it somewhere with HP tuners as well.
Re: oil pressure
SOrry to hijack but, has anyone personally been able to successfully get oil pressure readings from the torque pro app? I am trying as I type this with no luck.
Any help would be appreciated.
Re: oil pressure
What year is yours? I'm not sure that ELM327 adapters work on 2014+ vehicles.
Re: oil pressure
Mine's a 2013 9C3
Re: oil pressure
probably a little late to reply, but I just finished my dod delete. I attached a mechanical guage to the oil port at the back of the engine when i first fired up the car. After that I got the torque pro app and there is a way to monitor oil pressure through the settings. I have a 2015.
Re: oil pressure
Thanks,BJH27 wrote: ↑Sun Jun 12, 2022 5:35 pm probably a little late to reply, but I just finished my dod delete. I attached a mechanical guage to the oil port at the back of the engine when i first fired up the car. After that I got the torque pro app and there is a way to monitor oil pressure through the settings. I have a 2015.
Paul
[/quote]
Thanks for the info guys, mine is a 2011. I was finally able to get oil pressure to work in the paid version of the torque app. But I would be interested in putting in a mechanical one at some point.
Re: oil pressure
There is a PID for oil pressure. I monitor it when data logging. There is also a low oil pressure alarm that will go off on the DIC if the pressure drops below 25psi at high rpm or 5-6 psi at idle for more than 10 sec. I hope you never see it! ( I have)
2013 PPV Phantom black 1,077 RWHP 1,015 RWTQ 9.9@148
LS3 stroker 417ci, Callies crank w/ Malhe pistons & Darton sleeves. 11.5:1
Procharger F1a94. 22 psi boost E85
Water/Meth + 180hp N20
BTR custom cam 235/257 .638/.629 116, BTR shaft rockers Johnson 2126 lifters
BTR Trinity intake Kooks headers w/ Solo exhaust 3"
CDT Level 4 trans build w triple disc TC
Holley 120lb injectors
MT ET Street R 305/45/R18 on 10" widened OEM wheels.
