grinding/buzzing noise when driving
Re: grinding/buzzing noise when driving
Wheel hub swap completed today. It was only 95 outside, but it was a wet. heat. :lol:
It went surprisingly well, considering the car is from the rust belt. I did have to take a BFH to the old hub after unbolting it. Cleaned the mounting surface on the spindle and hit it with a coat of engine enamel. The new hub also got a pretty good coat of RPM (Rust Prevention Magic) all over before going on. Since I hadn't trimmed the dust shields, and it's been a minute since the big brake kit went on, I forgot the dust shield interferes a bit with the caliper. Not bad enough to cause any misalignment, or dragging of the shield on the rotor, but I thought I had messed something up installing the caliper the first time. That delayed completion of the project by another hour. Additionally, the stud that sticks up out of the end of the trailing lower control arm needed to be cut off so we could get tools in for the lower hub bolt. Remember that should you have to do this job. Angle grinder is your friend there. :D
The car seems quieter on the test drive, although I only got to about 45. Before the swap, the noise levels at freeway speeds were ~91-92 dB. I'll retest next time I get out on the open road.
Oh, and the engineer who thought it was a great idea to implement torque PLUS degrees of rotation needs many kicks in the nards!! I believe there's a special place in hell for that guy, standing right beside the GM engineer who invented Torx bits. :evil:
JoeR
Post by JoeR »
Torx works good when you need an internal drive and low clearance. I've found absolutely no reason for the triple square fasteners though. They suck.
Glad you got the bearing straightened out.
Joe
Pursuit
Post by Pursuit »
And, don't forget about the Torx Plus fasteners and bits... :P
JoeR
Post by JoeR »
Pursuit wrote: Mon Sep 23, 2024 5:53 pm And, don't forget about the Torx Plus fasteners and bits... :P
and the tamper proof torx!
Update. Got to take one of our pups. to her oncologist appt today, and cruising at highway speeds is a ton quieter. Seems that hub fixed my buzzing noise.
And the chemo were giving the pup. seems to. be helping. So far, good day!!
