Tap Shift for a 9C1 with a G8 Shifter
Please note & respect that Chris has full-time employment. General questions can be posted here, but for specific individual needs please contact him via his website. SPECIAL NOTE - We have no role or liability in any transactions other then to provide a venue to advertise the items. Disputes must be resolved independently between the parties involved in any transaction.
Hi, I wanted to know if you can add Tap Shift to a 9C1 using a G8 shifter (or 9C3 shifter same difference as far as I can tell).
My assumption is yes, as you seem to have done it for Kevin Sullivan, but honestly I don't know if that was a one off of some sorts, or just putting in the factory tap shift, and I don't see a tap shift option on the order page.
Also, do you need my BCM or can I send in any BCM I get from the junk yard?
I wanted to ask in case you need to copy the factory setup for my car for some reason.
Re: Tap Shift for a 9C1 with a G8 Shifter
Yes but please contact us from our website.
Chris White
2022 3LT Red Mist Coupe
2023 70th Anniversary Z06 HTC
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
also very interested in this. tried reaching out to you via the website and never heard back.
When did you contact us? We are only open on the weekends but typically try to reply at night during the week if at all possible.S13REMI wrote:also very interested in this. tried reaching out to you via the website and never heard back.
Chris White
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
about a month ago. Ill do it again today
FYI didn't get anything for a PPV (nothing in our spam either).
Chris White
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
Dragging this up, I just inquired on your website about this feature as well. I'm stuck between doing the BCM re-program, or modifying the shifter and using the Holden sport/TC switch like PPV did in his swap. I'd prefer to do it as per the factory and retain the tap shift function of the G8/9C3.
-2011 Caprice 9C1 (Gone)
Bump to this old thread. I'm in the process of installing a g8 shifter and would like to enable sport and tutd on the g8 shifter.
Aside from having chris program the Bcm. What are the wiring details?
I see from another thread is says pin 1 on the shifter goes to pin 17 on the Bcm . Then pin 4 on the shifter goes to 30 on the BcM.
Is that all there is to it ? What happens to my old gray Sport wire in pin 5 ?
Maxspeed96ct wrote:Bump to this old thread. I'm in the process of installing a g8 shifter and would like to enable sport and tutd on the g8 shifter.
ditto
2013 9C1 6.0 (27,xxx) 14.142 @ 103
2009 Malibu LTZ
1988 2wd Suburban Silverado
1972 Chevelle
1969 Camaro 350/350 X44
2009 Malibu LTZ
1972 Chevelle
Big Rich 01 wrote:Maxspeed96ct wrote:Bump to this old thread. I'm in the process of installing a g8 shifter and would like to enable sport and tutd on the g8 shifter.
ditto
Maxspeed96ct got his done and posted details on the wires:
http://newcaprice.com/forum/viewtopic.php?f=9&t=2377" onclick="window.open(this.href);return false;
Also check this thread on how to wire it up:
http://newcaprice.com/forum/viewtopic.php?f=21&t=1578" onclick="window.open(this.href);return false;
I did exactly as I posted there.
Both Maxspeed96ct and I didn't need any special programing to get TUTD to work in our cars after it was wired according to factory, so install and wire your shifter up first and test it out. if it doesn't work for some reason, Chris would be the man to talk to .
