Missing overhead console hardware
What's missing here? There is a spot for 4 screws but only one does anything. The other three apear to be missing clips or bushings:
Re: Missing overhead console hardware
Oops. My phone uploaded in a high res... I will try to edit it.
Lower res photo
- IMG_7036.JPG (26.48 KiB) Viewed 13318 times
Missing the dome light assembly and sunglass holder. I upgraded mine to a black one with map lights but you can get a tan one with map lights as well from AU or maybe the SS
Some extra wiring needed for the map lights to work:
WM Statesman Map Light Wiring
Tan one:
Tan one:
I have it. I took it off because it was making a horrible rattling noise. The plastic bracket pictured was missing 4 screws and 3 of some sort of square plastic washer.
I ended up using 4 new screws and 3 small fender washers to attach it and eliminate the noise.
Oh yes I see what you mean now. Yes they are plastic square washers. DO what works.
i need a tan one with the sunglass holder
i do have a black one with the sunglass holder , one with the sunroof dial , non-map light with sunroof dial , and 1 tan with the sunroof switches
i did put the rear SS dome with reading lights in my 14 , but the reading lights need to be wired in , also swapping the 14-17 front over head with a SS requires rewiring and a new plug , the SS uses a 6pin rectangular plug , and the ppv is a single row flat plug
