Oil catch can/location of crankcase vent tube
I bought the radium auto oil catch can and had a hell of a time installing (more like getting frustrated and hooking up all the stock stuff again).
In the location on the passenger side of the intake we have one plastic fitting for an EVAP line. On every G8 and SS install video on God's green earth they have a metal and a plastic fitting for the two hoses to connect to the catch can.
I could be retarded, which is likely, but their instructions are terrible and I'd like to know which other hose I need to use.
I know it won't be either hose that goes to the EVAP canister, there's a fitting on the driver side of the intake, the IAT line for the Maf/intake itself, and a line or two off the rear. Do you have any guidance for me?
Active Duty USAF
Active Duty USAF
Re: Oil catch can/location of crankcase vent tube
Can't help, sorry, but the verbiage of your post made me laugh.
If you don't have an answer when I get home from work I'll have a look at my car and see if I can help later.
Connect the catch can inlet to the port on the rear of the driver's side valve cover.
Connect the catch can outlet to the intake manifold behind the throttle body.
Connect the passenger side valve cover to the air intake tubing between the MAF and the TB.
Yeah for your first response I have no idea without being shown lol. Second response I'm guessing that's referring to the plastic fitting on the passenger side of the throttle body area (behind EVAP canister). For your third response I'm also at a loss. I have the OTR intake, if that helps at all.kevink wrote:Connect the catch can inlet to the port on the rear of the driver's side valve cover.
Active Duty USAF
Active Duty USAF
If you look at your engine while reading what I previously wrote, I'm sure you'll find the points I'm talking about.
You're talking to the guy who scratched his head for 6 hours on this, went to get a longer bolt and then blew a brake line on my other vehicle in the process. Had to fix it and drive it back. It was a day from hell. I appreciate the help but I'll most likely need more guidance lol.kevink wrote:If you look at your engine while reading what I previously wrote, I'm sure you'll find the points I'm talking about.
Active Duty USAF
Active Duty USAF
You should have a plastic line that on a stock setup goes from TB under and around to the driver's side valve cover. A similar line connects the passenger side to the flexible intake hose between TB and MAF and was probably modified when you did the OTR intake. Leave that part along if you are using a single catch can setup and find the one on the driver side, remove it from the valve cover and attach to the catch can and then attach something hopefully included in what you bought from the catch can back to the TB fitting. Maybe post up a pick of what you have as well as your engine?
I know I use the line next to my empty MAP hole, and is this yellow tipped line the one I need?
- IMG_20180717_170415.jpg (216.9 KiB) Viewed 13027 times
- IMG_20180717_170352.jpg (197.57 KiB) Viewed 13027 times
- IMG_20180717_170236.jpg (281.44 KiB) Viewed 13027 times
Active Duty USAF
Active Duty USAF
Believe you have it now sir... its called the "dirty side" of the LS.... Whats happening with all those crazy wires on top of intake mani?
I got it figured out! That plastic fitting to the driver side valve cover it all makes sense now, I remember on the G8 and SS videos it was just a U shaped hose between those two in behind the TB. Makes sense now. Thanks.xcidmigs wrote:Believe you have it now sir... its called the "dirty side" of the LS.... Whats happening with all those crazy wires on top of intake mani?
That's a MSD ignition wire upgrade. And I didn't reroute the hoses and wires quite the right way after throwing it back together last time.
And since I'm Irish and therefore so damn lucky, now I just have to deal with a brand new P0340 code for camshaft sensor!
Screw with your oil catch can and get a brand new engine code for free! You have to pay for the cost of a new sensor and drop your starter to fix the sensor, but after that it's absolutely free! Just pay blood sweat and tears.
Active Duty USAF
Active Duty USAF
