Page 9 of 12
Posted: Thu May 30, 2019 1:59 pm
by Tansman
CrashTestDummy wrote: ↑Thu May 30, 2019 10:01 am
Nice work. I have GOT to learn how to TIG!
That's not my work! I'm lucky enough to have a good neighbor who knows how to tig. If not this stuff would probably be costing me alot more.
I actually tried putting everything together last night, and that bung for the IAT ended up being the wrong thread pitch! I checked my amazon order and i checked the sensor. both say 3/8-18 npt. so i don't know if I recieved the wrong one or what, but i ended up basically ruining the sensor and the bung threads. I ordered a new one so it will all have to be re done. The new bung is from a better rated seller.
Luckily the MAF has a built in IAT, so i was still able to get it all together and running. The new IAT is just for when i get the meth running.
I've been trying to do as much research as I can on tuning. I have the idle pretty good for the new cam. But I'm still not 100% sure I have the MAF table right. I just stuck the stock table from a 2010 LS7 in it. Once my new map sensor comes in I might try to start street tuning it. Everyone seems to want $3-400 for an e-tune. but around here that is DYNO tune territory. So i guess i'll give it a shot!
Posted: Sun Jun 02, 2019 10:38 pm
by Tansman
ZR1 map sensor should come in tomorrow. And then I'm going to try this tuning thing out
Posted: Wed Jun 05, 2019 12:08 am
by Tansman
Well I got to take it out and drive it around today. Attempted to start tuning it in speed density. Didn't go terribly. But I'm having a hard time figuring out why its stalling every time I come to a stop. Its something in the idle tuning. I just don't know what. As far as boost goes, I was building around 4 psi (spring) and then it just quit building boost. I'm not sure why. I changed a couple things up and will try again tomorrow on my way to work!
Posted: Mon Jun 10, 2019 10:08 am
by Tansman
The tune is getting pretty dialed in on wastegate spring. I'll be turning it up soon once I think its ready! I put a couple hundred miles on it this weekend to find problems. Only major issue was I melted my hood latch cable!
Posted: Mon Jun 10, 2019 10:10 am
by Tansman
So I got rid of the hood latch, and had hood pins overnighted from Amazon. I like the way they look!
Posted: Mon Jun 10, 2019 10:11 am
by Tansman
I also cut some holes in my bumper to get a little more airflow in.
Posted: Mon Jun 10, 2019 10:16 am
by Tansman
One more note- so the 5in fender exit exhaust, with all the windows up cruising down the highway at 70-75. Is QUIETER than my wife's civic with a fartcan. If you roll the window down it's another story. But with them up its actually super quiet for what it is.
Posted: Mon Jun 10, 2019 5:03 pm
A spinning turbo will muffle a lot of noise. Had a friend who had a Mustang SVO he ran in Super Stock class back in the '80's. Don't remember what class specifically, but the engine was mostly stock, except for a big cam, big turbo and exhaust that essentially dumped right out of the downpipe. Rolling up to stage, the thing sounded like an uncapped 4-stroke bike with a big cam. When he let the clutch out, all you could hear was the 'whoosh' of the turbo, and he car in the other lane.....
Posted: Mon Jul 01, 2019 8:35 am
by Tansman
Small update. Been trying to get the tune dialed in. The G8 LS7 maf adapter harness I bought was pinned wrong. I re-pinned the stock plug and now its working good! But I was getting choppy maf signals. So I had to add a honeycomb .
- 20190629_124426.jpg (2.89 MiB) Viewed 17766 times
I'm also running out of injector at only 3psi. I'll push it a little further with the meth. But I won't be able to afford injectors anytime soon! I'm also going to need tires because with the cheap 275s I have it will spin all through first and second no problem.
Posted: Tue Jul 02, 2019 4:09 pm
by Tansman
I'm working on making my down pipe a little better today. It was rubbing my fender pretty bad so I but a small bend in it.
- 20190702_135521.jpg (3.39 MiB) Viewed 17743 times
I also heat wrapped it, and then put some high temp gloss black on it. And then I sanded the tip down with a flap disk and put some high temp clear over that. I'm hoping it will stay shiny.
