WTB: 6.0 A6 Engine/Trans Wire Harness (2012)
Post your Caprice PPV parts & components for sale here.
Schul274
Post by Schul274 »
I would like to buy a replacement wire harness for my 2012 caprice PPV (6.0). I believe I have a wire pinch/rub through in mine.
If anyone is parting out a car or has an extra, please let me know.
Tansman
Re: WTB: 6.0 A6 Engine/Trans Wire Harness (2012)
Post by Tansman »
I saw 66 auto salvage in Oklahoma has some they are parting .
2012 Chevy Caprice- VSR80 turbo, BTR stage 2, 3.45s, camaro wheels, meth injection (racecar/ weekend car)
2007 Honda Civic SI- Sedan- intake, exhaust, Skunk2 short shifter, shift bushings (wife's daily)
2005 Chevy tahoe- Cold air intake, everything else stock! (The family car)
2000 Honda civic Hatchback- lowered, rota slip wheels. (My daily)
PPV6.0
Post by PPV6.0 »
Did you find a harness yet? If not I may have one from a 2013. How much did you want to spend $$?
Capeasy
Post by Capeasy »
Is a 2013 and 2014 different?
And is the under hood fuse box the same?
Walt (AKA:Capeasy) So. Cal.
13 TO 14 are different , even the part #s for the 11-13 are different
11 part # 92253242
12 part # 92261877
13 part # 92268935
all of which are discontinued
Capeasy
Post by Capeasy »
Thanks, I ended up repairing mine. I guess it's common for these harnesses to deteriorate from heat from long periods of idling, at least mine was at the O2 connectors on the back of the engine.
Capeasy wrote: Wed Jun 05, 2024 1:44 am Thanks, I ended up repairing mine. I guess it's common for these harnesses to deteriorate from heat from long periods of idling, at least mine was at the O2 connectors on the back of the engine.
starter and crank sensor wiring will also need some care at somepoint , so keep that in your mind if you have the starter out , or exhaust manifold/header , as that frees up alot of space to repair them
Andy91954
Post by Andy91954 »
I need an engine harness for my 2012 ppv can anyone help?
I have looked and looked but can’t find one
Capeasy
Post by Capeasy »
I went thru the same issue, I called a few wiring harness manufacturers for motor swap projects and got quotes almost double what a typical LS swap harness would cost and would have to wait up to 3 months for it. So it was easier to just buy good quality connectors and all the other supplies to make my own, which was probably better quality and heat shielded than OEM.
Andy91954
Post by Andy91954 »
Yeah I know, I bought 2 wiring harnesses already and going to fix them up very well. Wish me luck
Users browsing this forum: No registered users and 0 guests
