Steering wandering at highway speeds
Like the title says, the car steers all over the road at highway speeds. All front end components seem solid, but I haven't given them a full test yet for worn parts. It seems to either want to pull left or right, and when it does it is fairly dramatic, not like a slight pull but somewhat hard. If I let the wheel go it will go left to right and back when the car hits bumps. Any ideas what could cause this? Simple alignment? Rack and pinion needs replaced? Any insight is appreciated!
Re: Steering wandering at highway speeds
I would personally get it to a reputable alignment shop and have them do complete inspection, front and back. Solid safety practices are better than speculations...
DON'T LET GO OF YOUR STEERING WHEEL WHEN DRIVING DOWN THE HIGHWAY!
I've noticed our '12 is sensitive to undulations in the road, and pulls a bit, depending on the amount of crown in the road. I suspect a bit more positive caster would help that, but as Maurice noted, get a reputable shop to complete an inspection. Most chains will want to tell you your entire suspension is shot if the car has more than 10 miles on the clock.
How many miles does your car have on it?
It has 93k on the clock now, but lots of hours. Was a cruiser in a small town here in SW Iowa.
Curious, what part of SW Iowa are you located? I'm in the Bellevue, NE area...
I'm in Council Bluffs, the car came from Shenandoah
PM sent...
Got the car to a mechanic today. He said the strut bushings are both bad and they move up and down with the movement of the wheels which is causing the left/right pulling and bump steer. From what I've read this is a common problem. However he recommended replacing the bushings, struts and sway bar end links all at the same time, even though the suspension parts are all "tight." Is it commonplace to replace the end links with the bushings?
One other related question, where do I find struts that won't kill my wallet? I found the poly bushings for about the same price as the factory replacement rubber ones so I'll order those asap.
Thanks!!
Thanks!!
Rock auto has Monroe struts for $88 and AC Delcos for $99. While you have it apart, depending on your budget, maybe consider different springs, if you were thinking of lowering it...
As far as the endlinks and such, the assemblies are apart, and the labor would be the same to put the old ones back on versus putting a fresh set on.
Mike,
My apologies, I just remembered that your car is a 2014. The front suspension design changed in 2014. The Monroe struts are $97 and the ACDelcos are $150 ish
