1/4 mile with Mod List
Posted: Mon Oct 26, 2020 10:42 am
by BarryM
First Time at the track with my Caprice PPV:
1.73 60'
7.85 @ 88.1 1/8
12.32 @ 110.7 1/4
155K mile short block and transmission - PPV Steel Rims
Camshaft TSP Stage 1 LS3 N/A Camshaft 225/236 .629"/615" 114 LSA, 109 ICL
Texas Speed and Performance CNC Porting and CNC Valve Job of # 823 factory heads
TSP DOD Delete
Camaro 6L80 deep transmission pan and wide mouth filter
Torque Converter - Precision Industries 3600
3.27 Limited Slip Differential
Kooks Headers, No catalytic converters, 2.5” SOLO exhaust
Roto Fab Cold Air Intake
Hoosier DOT Drag Radial Tires 245/40-18
PB1117SS - PowerBond Race Performance Harmonic Balancer
Oct 23.jpg (83.17 KiB) Viewed 9169 times
First time track.jpg (370.07 KiB) Viewed 9169 times
Re: 1/4 mile with Mod List
Posted: Mon Nov 09, 2020 9:47 am
by BarryM
Update - Improvement
Charles Barber tweaked, thanks sir !
Increased tire air pressure to 26
1.68 60'
7.73 @ 88.9 1/8
12.13 @ 112.7 1/4
Second time track.jpg (204.95 KiB) Viewed 9082 times
Posted: Mon Nov 09, 2020 9:57 am
by BarryM
Posted: Mon Nov 09, 2020 11:15 am
by kevink
Nice work. You can probably knock off a tenth or two with skinnies.
Posted: Wed Nov 11, 2020 10:22 am
You can probably knock at least half a tenth going with a wheel that's NOT the Caprice wheel. Those things are heavy, and going with even a different steel wheel will cut some rotating mass. Aluminum would be even better.
Posted: Mon Nov 16, 2020 9:24 am
by Turbopowered68
BADASS
Posted: Thu May 11, 2023 9:52 pm
by Nate68c10
Personal best last weekend at Cleetus and cars Indy
Tsp stage 1 LS3 cam
Circle d 3400 converter
Solo exhaust and jba long tubes
Camaro 3.27 diff
Hoosier dr2 drag radials
100 HP wet nitrous shot out of the hole
Posted: Thu May 11, 2023 10:10 pm
by Nate68c10
Posted: Thu May 11, 2023 10:44 pm
by GammaFlat
Great times Nate. How does all that grunt translate in terms of drivability? Does it feel good stoplight to stoplight?
Posted: Fri May 12, 2023 9:33 am
by Nate68c10
It's pretty good stoplight to stoplight. I need to have my tuner adjust some stuff around 45-50 mph but other than that it's pretty normal just bucks a little bit at that one speed range.
