PPVOS wrote: ↑Sat Feb 06, 2021 9:35 am
Will this wiring work with TUTD shifting?
Any info on how it will work with paddles on the steering wheel?
Ones wired up and you have the Trans tuner adjustment enabled it will to manual shifting from the shifter.
As Jrob56 mentions the paddle sifters (hooked up in the factory specification) are not active. We are hoping that can be turned on with a BCM reprogram. Now some guys have gotten the paddles to work on thier cars but I believe they are hooking into the spots that the shifter uses on the BCM. So what I and Jrob56 are trying to do here is recreated it as close to factory as possible when using a SS shifter and SS paddles. If you are not interested in that there are ways to make them work and that I think has been covered in other threads.
Also with that being said If I can remember I will also include a wire with the kits that goes from the vehicle side clock spring connector to the BCM spot for the paddle shifter signal. If you are already under there may as well hook up all the wires for when we hopefully have a BCM programming option for it. Then if you ever install a Wheel with paddles it will all be pre wired.
That’s cool with me, I can respect you wanting to make it as close to stock as possible as far as length and connections. I honestly wouldn’t mind having to but connect or even cut and use a totaling different connector on both ends, if those specific connectors are hard to come by. Let me know if you can make this for me. I’ll be pulling the dash to install the SS dash anyways but can wait to do that until I can figure out this harness. Appreciate the help!
RM96 wrote: ↑Mon Feb 08, 2021 5:33 pm
Here's a picture of the currently selected gear being illuminated red in an SS.
Yeah I checked mine and doesn’t light up red either, I’d bet that lies in that LIN pin and BCM, but I can’t say for sure.
Just realized the SS shifter does not have LED back-light control. So at night if you guys dim your dash lights does the shifter dim? Or stay just as bright? Wonder if the SS guys are the same? Or could back-light be dimmed through the LIN??
No back light control, I usually keep mine full bright but finally dimmed them one night and noticed it. I’d bet SS guys do and not sure if BCM and LIN controlled or not.
Can I add the paddle shifters and keep the column shifter? Call me strange but I like it on the column. Sorry if this is answered and I missed it. Thanks.
Jesse
