2013 Chevy Caprice PPV
Clear PA Title in my name
Current PA State Inspection and Emissions
Less than 160K on car
30 miles SE of Pittsburgh PA
$12,500
Less than 2500 miles on the following mods:
DOD delete using Texas Speed Stage 1 LS3 N/A Camshaft #25-TSP225236 225/236 .629"/615" 114 LSA, 109 ICL
Heads
Texas Speed and Performance CNC Porting and CNC Valve Job of # 823 casting L92/LS3 (rectangular port) heads -Skim cut to head sealing surface, .005”
PAC Springs
LS7 Lifters
Titanium Retainers
TSP Chromoly Pushrods
LS3 rockers with CHE bushings
ARP2000 Head Bolts
NGK BR7EF
Taylor Thundervolt wires and boots
Shortblock
Melling 10295 Oil Pump
Improved Racing Pickup Tube Brace
LS2 Lifter Trays
LS2 Timing Chain
LS2 Chain Dampener
LS3 Cam Retainer
PB1117SS - PowerBond Race Performance Harmonic Balancer
Charles Barber Tune - (awesome guy to work with)
Trans
Camaro 6L80 deep transmission pan and wide mouth filter
Torque Converter - Precision Industries 3600 Vigilante
Lokar dipstick
3.27 Limited Slip Differential
Kooks Headers, No catalytic converters, 2.5" SOLO exhaust
Roto Fab Cold Air Intake
Nitrous Outlet 200hp single nozzle kit fed with two ten lb bottles - dual bottle bracket with heaters
Lingenfelter Timing Retard Launch Controller
10 passes at track, best ET 11.77 @ 119, 1.62 sixty foot on motor – no spray
(Has not been sprayed at track yet – but has been tested on street)
Spare Parts Included
Two complete steel rims and centers with Hoosier DOT Drag Radial Tires 245/40-18
Two Widened Factory Rear Steelies with centers and a larger Hoosier DOT Radial
325/45-18 Hoosier DOT Drag Radials
Tire Diameter: 30.20 in. Section Width: 13.10 in. Tread Width: 11.20 in.
LS7 7.0 liter 427 short block
Complete 3.45 LSD Differential with Jannetty Racing Posi Mod kit - Kevlar clutches, new axle seals
Spare low mileage driveshaft
Complete custom driveshaft for 400 Turbo Install
Listings acceptable to post in this section are Caprice PPV's for sale by individuals, government entities (I.E. direct sale/auction/sealed bids), and the occasional car for sale on dealer lots (trade-in's for example) that do not normally sell Caprices. EBAY/Craigslist/auction site ads are OK for the above as well. Please do not post third party ads for cars on behalf of dealers that routinely sell used PPV's as part of their primary business. Listings by members with under five forum posts may be removed without notice, please check with a moderator if you have questions. SPECIAL NOTE - We have no role or liability in any transactions other then to provide a venue to advertise the items. Disputes must be resolved independently between the parties involved in any transaction.
- 1.jpg (1.4 MiB) Viewed 1221 times
- 10.jpg (753.19 KiB) Viewed 1221 times
- 3.jpg (752.36 KiB) Viewed 1221 times
- 9.jpg (880.66 KiB) Viewed 1221 times
- 6.jpg (727.45 KiB) Viewed 1221 times
- 4.jpg (756.91 KiB) Viewed 1221 times
Re: 2013 Chevy Caprice PPV
Solid but whomever picked this up.
