P0521 with low oil pressure
Hello.
I have l77 engine and I replace all of these :
All Gasket and seal
All Lifter with Guide
Camshaft with bearing and retainer plate
Crankshaft polishing and use new bearing with 10 size
Oil pump with 0304 no. and screen with O-ring
New DOD.
Oil use 5w30
After this I have P0521 code all time and the pressure drop when idling to 56 kpa I replace the oil pressure sensor but code still.
All Gasket and seal
New DOD.
Oil use 5w30
- Screenshot_٢٠٢٢٠٨٣١_٠١١١٥١.jpg (178.08 KiB) Viewed 2402 times
- Screenshot_20220912_175921_com.us.thinkdiag.plus.jpg (468.39 KiB) Viewed 2405 times
- Screenshot_20220912_175525_com.us.thinkdiag.plus.jpg (555.88 KiB) Viewed 2405 times
- Screenshot_20220912_175409_com.us.thinkdiag.plus.jpg (496.97 KiB) Viewed 2405 times
Re: P0521 with low oil pressure
Problems I have knowledge of:
Other potential problems that I've not seen with my eyes:
- oil pickup tube 0-ring seal is not seated or wrong size - sucks some oil and some air
- oil passages for DOD are not blocked off correctly (puking out oil and pressure freely) - friend had this on an engine he bought
- oil pump problem - pressure relief spring too short or non-existent or high clearances inside pump
- missing or high clearance crank bearing - if it's not knocking
- foot of oil pickup is on bottom of pan (not "clearanced")
O-ring same size and seated.
DOD replaced two time one by used and the last by new one.
The low pressure only after 90c or more when cold 300 kpa and more.
What about the bypass in the oil pan? Did you plug the secondary oil bypass valve in the oil pan? If your oil pressure readings are accurate then that could be a source of low oil pressure.
P0521 code
- The engine oil pressure is out of its working range.
- The ECM does not detect a change in the engine oil pressure.
- The engine oil pressure is outside of a calculated working range determined by engine speed and temperature.
Troubleshooting the sensor is pretty simple. One wire is ground. One wire is 5v from the ECM. And the other wire is variable positive 1-5v volts from the sensor the ECM uses to calculate oil pressure. Should have less than 10 ohms resistance between plug and ground and 4.8–5.2 volts on plug with key on.
P0521 code
If you mean oil relief valve, Not replace.
- IMG_20220914_000943.jpg (2 MiB) Viewed 2377 times
- IMG_20220914_000812.jpg (1.9 MiB) Viewed 2377 times
- IMG_20220914_000802.jpg (1.85 MiB) Viewed 2377 times
Can switch from 5w30 to 10w40 fix??
In your picture of the connector you measured the #2 pin (right) which is the 5v reference voltage. So that looks good. Next you need to measure the ohms on the #3 pin (left) from the pin to ground. Anything more then 10 ohms indicates a bad ground. The top pin, #1, is the input pin where the variable voltage goes into the ECM so it can convert it to pressure. A small change in oil viscosity is not going to drastically change your pressure. The secondary oil relief valve in the oil pan could be causing your issue. At 1,000 rpm with engine hot the minimium oil pressure should be at least 24 psi stock. First thing I would do is remove the oil pressure switch, install your own gauge and then you will know if it is an internal engine oil pressure issue or external electronic issue. Then troubleshoot from there. What model oil pump is in there and what color spring is in the pump? Also I think there is a small screen underneath the sensor. Check it.
Thanks for your reply and help.
Oil pump # 12710304 ana I am not sure about spring.
I put new screen.
I put new screen.
That is an OEM pump, standard pressure, high volume, so thats fine. Should also rule out internal oil pump spring (42 psi) and rule out secondary bypass unless it is malfunctioning. Next step pull the sensor and put an oil pressure gauge on it to narrow down either mechanical issue or electrical/sensor issue. Also what is the psi with the engine at operating temp and held at 1,000 rpm?
One mechanic said change to #12612289 will fix !!!
At 1000 rpm = less than 24 psi may be 136-150 kpa.
