fender roll suggested for camaro 20's
With my car fully loaded in the trunk and 3 people, the rear tires will rub the fenders with the slightest bump. I have 275/40/20 in the rear and 245/45/20 in the front. I also had to pound on the bottom strut plate to fit in the front. It ever so slightly rubs now. Going to get my fenders rolled and test out a spacer for the front. Little trial and error ha.
- 20140729_153031.jpg (128 KiB) Viewed 19193 times
- 20140803_165308.jpg (1.53 MiB) Viewed 19193 times
2011 9C1 Charcoal Grey--
Chris White programmed Radio
2012 Camaro SS 20's Nitto Invo tires
Re: fender roll suggested for camaro 20's
Our experience with Scott Walker's car bears this out. With 275/35-20, rolling of (rear) fenders was 100% necessary--it's a width and offset issue, not tire height. 275/40-20 is really too tall (well, I mean that it's a good bit larger diameter than OE PPV tire--28.7" vs 27.3")....it will work, but does it look "right"? Probably helps fill up the wheel opening, but plays havoc with overall gear ratio and speedometer accuracy....may even worsen fuel economy.
It's really the offset on the Camaro rear wheels, which are +40mm & 9" wide--compare them to the SS sedan rear wheel ("most correct" for OE comparison), which has a +57mm offset & 9" width.
can you repost the first pic?
So will stock Camaro SS wheels work with the fender roll? The mention here about contact with the strut plate worries me as well. The first pic won't load so I can't tell how they look. If I can I'd like to get a set of these for mine.
2011 9C1
2005 GTO
2005 GTO
Was Scott's car lowered at all?
Thanks,
Tom Slick
Thanks,
Tom Slick
Yes, my car has coil overs on it. still get a rub if you hit a dip but not bad. Rolling the lip is an art and if you have someone that does not have experience rolling G8 fenders you will have a dimple right in the center of the lip like I have on both sides. I have had 2 different guys work on my car to get it right.
Scott Walker
walker2311@att.net
2013 1LE Camaro
2011 9C3 PPV,wm rear spoiler,rear diffusor, lower chrome trim, wm rockers ss, fog lights, lower grill, chrome/black door handles, custom recessed factory grill, coil overs coming 2013 Camaro wheels in midnight silver in 20 x 8 and 20 x 9, 2014 SS exhaust tips
1952 Chevy Truck LS Conversion
1967 Chevy II Nova
1967 Chevy II Nova 1 Owner (just got her)
1964 Ford F100 (Bastardized in early 80's with chevy stuff)
1971 Datsun 510 (LS project ? Have a motor setup)
walker2311@att.net
2013 1LE Camaro
1967 Chevy II Nova
So is rubbing an issue with stock ride height then?
2011 9C1
2005 GTO
2005 GTO
I'm curious, too...
It's time for me to buy new tires, and I was thinking about picking up a set off Camaro Take-offs with tires already on them...
My 9C3 is stock ride height...
Later,
Tom Slick
Later,
Tom Slick
Stock ride height with 20's at close to factory tire height you should be fine. Camaro tires are too tall regardless
Scott Walker
walker2311@att.net
2013 1LE Camaro
1967 Chevy II Nova
walker2311@att.net
2013 1LE Camaro
1967 Chevy II Nova
I understand that they are too tall, but do they rub at stock suspension height?
