Rad/Heater Hose compatibility across 2011-2013 and 2014+
Rouge31
Post by Rouge31 »
Do the 2011-2013 radiator and heater hoses fit a 2014+?, when I’m shopping online everywhere I see has a cut off due to the model update in 2014. My lower heater hose has failed and while I have the part for that, the auxiliary hoses above have been discontinued and I cannot find a single one designated for the 2014+ caprice. I would prefer OE placement hoses although they don’t need to be GM/Holden branded I would prefer at least the same quick connects, or using a 2011-2013 hose set to update both at the same time.I have tried to search for a thread explaining this although I have yet to see it as I see many people opting for the relocation option.
Re: Rad/Heater Hose compatibility across 2011-2013 and 2014+
lower rad hose is the same , both upper hoses
oil cooler hose from the T down is 12-17
heater hoses show to be different on the rear half that connectos to the heater core , the front half that connects to the water pump is the same
