How To - Convert Factory Key to Aftermarket Flip Key
Re: How To - Convert Factory Key to Aftermarket Flip Key
I just went to a locksmith. $30/key since they are laser cut.
I basically just used the remotes I had in the original keys. Was a good thing since my originals were starting to crack and get worn.
Steve,
Did you ever do a video on disassembly and reassembly of the flip key fob? I'm looking to do this mod now but I need to figure out how the flip key fob comes apart.
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
Not by Me but a 6 part video series here. See if it is clear enough and report back.camrat68 wrote:Steve,
https://www.youtube.com/watch?v=gzm3J6qItEA" onclick="window.open(this.href);return false;
Outstanding! That should work.
Thank you.
Thank you.
Jim Chesnutt
One done, three to go.
Jim Chesnutt
Decided to go ahead and get mine cut. I had an '11 that my wife totaled, and I kept 5 of the 6 keys. So... I gutted them, just like the instructions here. I didn't want to sacrifice a good working key, as this one only came with 3 keys. I only screwed up 1 chip, and had to tear up another key to get one out. I had already programmed the remotes so.. BOOM easy swap. Chips read fine, followed the instructions in the service manual for programming them to the car. Total spent including cutting and all was 42.00 a key... Totally worth it..
- 0214181808a_resized.jpg (258.32 KiB) Viewed 21763 times
2013 9C1 Bone Stock
2013 9C1 Bone Stock
Update on my little adventure in flip key conversion.
The first two I did worked out fine. I was able to order the 2 for $40 deal but then they went to terminal backorder and I had to order from another manufacturer. I put the third key together just like the first two but the third key triggers the immobilizer warning and won't start the car. I learned the new key using a good key, put the new key in and it starts the car. I thought it was OK to use but it won't start the car again and I'm trying to figure out what I did wrong.
I pulled the transponder from a working key to use in the flip key. Did I fry the transponder chip trying to re-learn it?
Jim
Jim
Jim Chesnutt
Thanks to Steve and others for their input! Three things to straighten out:
Now I have a "switchblade" or flip key working!
I removed roll pin and used my old blade. I was not excited about paying 30 or more to cut a new key.
I wrecked the immobilizer chip trying to remove it (crap! - but happy ending).
Thankfully, the immobilizer that came with the new key worked fine (after procedure).
Thanks!
To get new immobilizer working:
Depending on the old fob you're taking apart, it is probably better to just use the new immobilizer (and program it of course) instead of trying to transplant the old one. I wrecked one knowing exactly where it was. It is molded in nicely. Maybe there are seams that are some how breakable that I couldn't take apart.
- old blade re-use or cut new one
- immobilizer sync
- remote (lock, unlock, trunk, remote start)
Thanks!
- put in a good key and start the car.
- remove the good key and within 15 seconds, put in new key with new immobilizer and start the car.
- Watch for immobilizer warning on dic. If no warning, I believe you're good to go.
- gather all remotes you want to work (a must)
- navigate to menu for programming remotes "Remote Key"
- Read instructions if you want or hit "Program"
- press and hold Lock and Unlock simultaneously until double beep confirmation
- do next key (until all key fobs are set)
Can't see your ebay link. Think that is your order data link not the auction link.
And yea the grinding out of the chip is a delicate process . Surprised myself when I got it the first time.
Steve,
Here's the link that I intended: https://www.ebay.com/itm/152530753300 for the key that worked (I paid a lot more than the current 26.91 price). It works but I'm not sure if I'd recommend it if you need 2 keys.
There is a "2 key" purchase that I "think" will work that is (or was) 50 bucks on ebay. I cannot be certain that the "2 key" deal would work but if I had to do it over... more details: I had an exchange with the seller who insisted that the keys would NOT work on my 2013 Caprice after I explained that their listed part number in their listing (92237316) was what I needed. I think they did not see it on their compatibility list and did not want to indicate in any way that it would work.
